Trans fix worked
Trans fix worked
I purchased and installed 2 ferrite filters on my negetive alternator wire from alternator to passenger side battery and wa laa no more trans hunting from 3-4 trans shifts great now.Thanks guys
quick question because my truck won't shift from 3rd to 4th... is this the same issue you had? driving at 55mph at or above 2,500rpm?
if so this would be awesome to know because i was going to dealership tomorrow to get pcm scanned for $80.
as for not shifting into 4th, more likely the 4th gear solenoid is failed, you would have to drop the tranny pan to replace it, easily done.
good luck at the dealer! you may or may not get good service or results, you would be better off going to a reputable transmission shop, most will diagnoise for free
the above fix is for the torqueconverter locking and unlocking, usually caused by bad grounds or electrical noise from the alt, there are many different "fixes" some work some dont.
Dealer scanned the pcm, apparently the transmission is shifting into 4th gear. So with that being said he told me its either the solenoid is bad or a broken wire in the od wiring harness.
okay im at a lost here what does this do im not use to the way my trans shifts it seems differnet from any other diesel truck i have driven it seems to shift in and out of gear alot is that what yall are talking about or im i just a retard?
4th gear and TC lock up are controlled by the PCM, all the other shifts are mechanically controlled via the valvebody.
odds are pretty good its the solenoid, you can use a multimeter to test the wiring harness, after you drop the tranny pan
VADSLRAM
03-26-2009 11:42 AM
03quadduallyho
02-02-2003 07:06 PM
