Tranny temp when towing
I drive a 99' dodge dually,andtow a 38' fifth wheel. At 60 mph the trans temp is about 160 degrees,When goin thru towns and in bumper to bumper trafic the temp sometimes goes to 210 degrees.What is normal? thanks,skippy101
when your going 60 your TC is locked, so your temps are low. In town you not locked. And that's when the heat comes in to play. If I'm messin around I can hit 190 (usually 170-180 though) in town empty.
I have about the same temps as you pulling my 26ft TH loaded up. But I've never gone over 195 loaded or empty..
Same temps here 160* hwy speed, in town can shoot to 230* quick but normally 210*. My gauge is in the hot line not the pan so I'm not too worried as it should cool before entering the trans again but I change the fluid every 15,000 miles just to be safe. I'm hoping my new trans will run cooler.
cool down tranny that is with a automatic.
tranny temp wnen towing
thanks Guys
I got seven replys to my question about my tranny temps,all seven are on the same page so thats good enough for me. thanks Again
Skippy 101
PS my sender is mounted in the hot line at the radiator.
Skippy 101
I think the best place for an auxiliary cooler and fan is under the bed. I put one in when I used to plow and it dropped plowing temps almost 50*. If it's under the bed it draws much cooler air than up at the front, this makes it very effective for stop and go traffic when there's no airflow up front.
I put in the front bumper, between the ports that direct air to the front coolers. If I had to I could bypass the remote cooler (back to stock) in 5 minutes with a screw driver. No pics, my camera is dead.
wise_cummins
12-24-2008 08:11 AM
