View Full Version : Tranny temp sensor port
ClassA4x4
02-22-2011, 03:49 PM
Can one of the pressure ports be used for conveniently inserting the temperature sensor? If so which one would get the mnost fluid?
Greed 93
02-22-2011, 08:52 PM
I had mine in the port going in from the back where the o/d section bolts to the case. it was about 20 deg. cooler vthan the hot line.
ARbowhunter7
02-22-2011, 09:06 PM
1/8" NPT fitting?
ClassA4x4
02-22-2011, 09:10 PM
where is the hot line?
Greed 93
02-22-2011, 09:39 PM
well hot line is the forward cooler line in stock trucks have a temp sensor there already. You have the motorhome setup right ? And yes 1/8 npt
ClassA4x4
02-23-2011, 06:22 AM
Thank you.
