Tranny Slip????
Old 10-27-2003, 10:05 AM
DTR'S Chaplain
ramlovingvet's Avatar
Tranny Slip????
I am experiencing a new problem on my 99. I will be cruising along at 45-65 and my engine will surge like a transmission slipping. It only does it once in a while, but seems to be more often. Also this Morning on my way to work my cruise control kicked off with out my touching the brake.
My guess is a sensor..
Any advice will be great.
Thanks ???
Old 10-27-2003, 03:41 PM
Diesel Dave's Avatar
Re:Tranny Slip????
I would try the apps reset procedure first to see if that helps with anything and then go from there if you have to. The apps reset procedure seems to help with some issues similar to yours. You can do a search on this site to find the exact directions. It is very easy to do and best of all it is free! Good luck.
Old 10-27-2003, 05:03 PM
billg's Avatar
Re:Tranny Slip????
I think this might help http://www.dodge-diesel.org/faq/faq....p;onlynewfaq=1
Old 10-28-2003, 09:17 AM
DTR'S Chaplain
Re:Tranny Slip????
Well I tried the rest and it made no dif.
I am now notice it only seems to happen when I am using the A/C..
Thanks for the Info Guys
txsmokindiesel
05-19-2009 08:03 AM
ramman21921
07-21-2005 04:57 PM
dkinzer
05-23-2005 08:57 PM
silverram323
24
11-09-2003 07:48 PM
BADodge2003
08-24-2003 07:22 PM
Quick Reply: Tranny Slip????
