tranny mount pic
Old 08-10-2011, 05:51 AM
Unless it's untaxed, then it's red.
#2isgreen's Avatar
tranny mount pic
Does this look like its bad enough to cause my mystery acceleration vibration?
The rubber feels pretty soft.
Old 08-10-2011, 04:29 PM
gyman98's Avatar
It looks pretty good, check the crossmember to make sure its not cracked. Accel vibration is not usually a trans mount, that sounds more like U joint or carrier bearing( although the carrier looks new) make sure all your U joints have angle to them and arent straight or they will vibrate and wear out quicker. Trans mounts usually give a knock when you shut the truck off if they are bad
Old 08-11-2011, 05:52 AM
#2isgreen's Avatar
I've replaced he carrier bearing, and pushed / pulled all he universal's, no play in there.
What its doing is under normal acceleration around the top of first gear andinto second fear the whole truck starts to shake like km drive over a badly washboarded road. 5 times worse than hitting rumble strips at low speed.
I'm starting to wonder if its from inside the tranny.
J10495T
09-21-2011 04:07 PM
DMS1707
23
11-05-2008 12:53 PM
chw
12-25-2006 04:30 PM
ckennedy
10-18-2004 03:29 PM
12valve@heart
08-11-2004 03:43 PM
Quick Reply: tranny mount pic
