tranny fluid?
Old 11-25-2003, 07:48 PM
vtailflyer's Avatar
tranny fluid?
Hi Everyone,
I am getting ready to change my tranny fluid and install a temp gauge and inline filter.
Any recomendations on what fluid?I am confused after some reading on the forums and net
ATF+3 is available localy at the shell bulk oil dealer, is it worthwhile to use dextron with the friction modifier? Or is ATF+4 even though not a full synthetic worth it? ???
Old 11-25-2003, 07:57 PM
Mostwanted's Avatar
Re:tranny fluid?
I would like to know as well.
Old 11-25-2003, 09:20 PM
kd460's Avatar
Re:tranny fluid?
ATF +3 is the safest bet. I know it's a little harder to get and costs a little more, but that's what the manufacturer calls for. If you change it regularly, then no worries. I have read that others have used dextron without modifier and have had no problems. I believe it's on an individual basis. Some have had to use the modifier due to shudder. I think it will shift firmer with the dextron. Ford has the "grabiest", then dextron, then atf +3. If using dextron, just be careful with the modifier. Hate to put to much in and encourage slipping.
I thought atf+4 is synthetic. It sure costs as much as a synthetic. Correct me if I'm wrong, have not done much homework on it. Hope this helps, Kevin
Old 11-26-2003, 09:11 PM
vtailflyer's Avatar
Re:tranny fluid?
I found a thread on another forum and it quoted "Appears that DC is using the legal synthetic marketing trick and it is merely hydro-cracked pretroleum crude based. Better, but still not synthetic "
It appeared to be backed up by substantail info. It also seems quite pricy, I think I will stick with ATF+3 on my change.
Old 11-26-2003, 11:14 PM
Srigs's Avatar
Re:tranny fluid?
I had this same question. I checked with the local dealer and for the 97 (mine) I need to use the ATF+3. I did and works great after the change.
Old 11-27-2003, 07:49 AM
kd460's Avatar
Re:tranny fluid?
So they are playing the same game that some of the oil manufacturers are playing? (like shell rotella t "fully synthetic" castrol, and valvolene blue?) it funny how they can get away with this play on words.
Instead of calling it a synthetic, why can't they call it "a premium conventional" . Thanks, for the info, Kevin
Old 11-27-2003, 08:20 AM
richard's Avatar
Re:tranny fluid?
I'll stick with the ATF+3
Old 11-27-2003, 10:42 AM
pappyman's Avatar
Re:tranny fluid?
I ran ATF+3 for a year after my tranny was rebuilt....I just did a tranny fluid change and put in Amsoil Synthetic Automatic Transmission Fluid and so far the shifting has improved some and I think the torque converter is locking up a little smoother
Common
06-09-2008 12:16 PM
Tommy93w350
06-26-2007 04:42 PM
2500
10-02-2006 09:14 PM
icrider
09-27-2006 03:10 PM
Quick Reply: tranny fluid?
