View Poll Results: What Fluid are you using that works?
$$$$Dodge Part$$$$$ Fluid
15
33.33%
Amsoil 5-30 HDD
17.78%
Redline MTL
26.67%
Pennzoil Syncromesh
15.56%
Royal Purple
4.44%
Something NOT mainstream
2.22%
Voters: 45. You may not vote on this poll
Tranny Fluid Poll
Old 12-09-2004, 09:09 AM
Lowco's Avatar
Tranny Fluid Poll
My 03 6-speed is crunchy, notchy, grindy when cold (below 40F) especially going to third, but 2nd and 4th are noticable too! It is coming up on 30k with the factory fill trans fluid and I want to change ALL the fluids out at 30k. What tranny fluid are you guys in colder climates using and is there any noticable difference in shifting smoothness from the stock fluid?
Old 12-09-2004, 09:46 AM
Lowco's Avatar
Come on guys, Chime in here!
I need to change this factory crap out before it wears my snycros or something!
Old 12-09-2004, 11:04 AM
rossn2's Avatar
Redline MTL......Changed mine a 7k miles and no complaints. You still may experience a little grind when really cold...but once warm it'll be slicker than butter.
Don[t put engine oil (AMSOIL) in the transmission...The Trans needs oil specifically designed for a manual transmission! Put the AMsoil in engine, transfercase, frt & rear ends.
For factory fill, when cold just hold cluth in a little longer (hesitate) when shifting between the gears, let engine rpms drop a little lower too.
Oh, Dodge part is Pennzoil Syncromesh and I wouln't even deep fry a turkey with it!
Old 12-09-2004, 11:19 AM
MikeyB's Avatar
I went with Pennzoil Synchromesh. So far no complaints, does shift better now than with the factory fill. Next time I might try Redline MTL.
MikeyB
Old 12-09-2004, 12:35 PM
MikeyB's Avatar
Rossn2,
I think the factory fill is Texaco/Shell MTX.
MikeyB
Old 12-09-2004, 03:23 PM
Jerry R's Avatar
I run MTL in the six speed, C+ in the transfer case and 75w90 in the diffs. Redline made everything quiet and smooth.
Old 12-09-2004, 08:43 PM
AaronT's Avatar
The factory fill, plus the DC manual transmission fluid is Pennzoil Syncromesh previously known as Texaco MTX.
Old 12-09-2004, 09:41 PM
tdupuis's Avatar
Location: New York City / Terre Haute, IN / San Antonio, TX
I just switched mine out with the factory Mopar fluid (took them 30 minutes to figure out what the hell kind of fluid it took, only to say "We have to order it."). AutoZone didn't have any Pennzoil Synchromesh, and they said that they can't order it. Load of BS, I'm guessing, but whatever. Mileage on the truck was 9338 with the original fluid. It was pretty smooth, but made some noise. Now it's smooth as silk and doesn't make any noise. Also, before it would grind into 3rd on occasion (don't know why), now it doesn't.
Old 12-10-2004, 08:42 AM
Lowco's Avatar
Thanks for all the responses guys. I'm looking for a few more before I make my decision. I'd really like for those having the same problems as I am with cold notchy grindy shifts tell me what actually worked or didnt work. I ve done all the research and it is one of the well kept secrets as to what this #4874464 really consists of! I want to run a synthetic but feel the factory stuff isnt a syn and Pennzoil FOR SURE IS NOT! Rumor has it #4874464 is a 5-30w oil with maybe some friction modifiers of some kind.
PLEASE HELP!
Old 12-10-2004, 08:59 AM
rossn2's Avatar
The #4874464 is Pennzoil Syncromesh....
Amsoil recommends to use their engine oil in the trans. No way.....
Go with Redline MTL. Cheapest I found was at http://www.myoilshop.com/
Old 12-10-2004, 10:15 AM
big red psd cc's Avatar
Used the Synchromesh.
I think most all of us have had the notchy shifts.
The fluid change made all the difference in the world.
Old 12-10-2004, 01:58 PM
rock's Avatar
I put in Penzoil Synchromesh and yes shifting is smoother. I have 24K on the truck. Changing it was a snap once I found a 17mm allen
Old 12-15-2004, 11:29 PM
Lowco's Avatar
As you know i have been stressing over which fluid to run in the 6-speed with 30k on it. Well today I took the plunge and filled it with Mobil 1 5-30w. I shopped for the Pennzoil Syncromesh, but was only able to find 1 or 2 bottles here and there at different parts stores, SOOOOO I was in Walmart looking and just picked up a jug of Mobil 1 and dumped it in tonight. WHAT A DIFFERENCE! Drove it to dinner after the change WOW! Shifts like a hot knife through butter now! I hope it stays that way for another 30k. The 30 degree morning tomorrow will be the REAL test for cold shiftability. Will let you know tomorrow when i get to work, but I think it will work just from my first test drive with it. Worth the $20 investment to try it. Pennzoil would of been $4.99 a qt. x 4 Mobil 1 is $19.89 for a 5 qt. jug plus I use it in my wifes camaro at 10k mile changes. Amsoil, Redline, Royal Purple are too expensive and hard to find on a shelf anywhere. My next change will be the tranfer case and front and rear axels. I'm going Mobil 1 in those too!
Old 12-16-2004, 07:00 PM
Hounddog's Avatar
Mobil 1 5w30 motor oil? or trans fliud?
Old 12-17-2004, 08:37 AM
Lowco's Avatar
Motor Oil
I got the idea from Amsoil recommending their 5w-30 motor oil for use in our NV5600 transmissions. Figured if Amsoil will work in it, Mobil 1 should too! IT DOES WORK!!
Quick Reply: Tranny Fluid Poll
