trailer wwireing help
Old 09-14-2011, 08:59 PM
rdr140's Avatar
checking my lights on my trailer to night i. i have right break lights and no left break lights all outher lights work . on it and the truck . got out my test light 7 pin with break controler . i have no power on the left side of the trailer conector any help would be appreatied i know i have a blown fues on the #1 fuse under the hood with i''ll replace tomarrow so i switched a nother 40 amp fuse for it . still no break lights on the left side . the yellow comeing into my breakaway box is not hooked up the left side tail lights are hooked to a red wire . ?????????????? is the trailer not wired right ????????? help . thanks robbie
Old 09-14-2011, 09:07 PM
With age comes the cage
Colo_River_Ram's Avatar
Your truck has separate fuses for the trailers Tail/LT/RT look under the fuse box cover for the layout. Trailer wires can be any color the good ol days of universal wiring is gone..
Old 09-14-2011, 09:24 PM
rdr140's Avatar
thanks checked them but will recheck tomarrow . still doint know why i doint have powe to the left side of my fact plug any thoughts ?
Old 09-14-2011, 09:35 PM
Totallyrad's Avatar
If the fuses are good and the circuit is in use about the only things left are a faulty wire, bad control box (TIPM) I think, or a bad ground on the test light.
Old 09-14-2011, 10:05 PM
On the backside of the 7 pole plug is a plugin to the main harness, check your lights there. if your good there you can repair or replace it with one of these:
http://www.etrailer.com/Accessories-...893-11933.html
If you don't have the signal there then it's like rad says your IPM / FCM is fried (TIM did not show up till "06") if that is the case you will need to add one of these:
http://accessories.etrailer.com/search?w=modulite%20hd
As replacement on your relay box will be $750 or so..
These are handy for trouble shooting things:
http://www.delcity.net/store/7!way-tester/p_791230.a_1
Old 09-14-2011, 10:20 PM
rdr140's Avatar
thanks crr i
l check it tomarrow morning and thanks for the links . u have been a great help
robbie
Old 09-14-2011, 10:50 PM
Your welcome,
If your not familiar with the rear bumper 7 pole plug to main harness connection it has a red tab that must be pulled out prior to disconnecting it..
Old 09-15-2011, 01:32 PM
SOhappy's Avatar
My left turn/break trail light went out on my '03 a couple of years ago, traced it to the TIPM. Installed a Modulite based on Colo River Ram's suggestion and all is good.
Old 09-15-2011, 04:19 PM
rdr140's Avatar
going to order the moudlite tomarrow . thannks for ur help crr u the man.
robbie
Old 09-19-2011, 10:52 AM
rdr140's Avatar
crr witch kit do i need for my truck . i see the 75 $ and the 55$ is the 75 easer to install . thanks agin for all your help . robbie
Old 09-19-2011, 11:12 AM
Robbie,
This kit will work:
http://www.etrailer.com/Wiring/Tow-Ready/119190.html
To the right of that page is a pdf of the installation instructions.
Under the instructions is a wiring kit if you do not have a roll of 12 ga and a fuse block you might want it too..
Keep in mind that the 4 way plug that comes with the kit will have to be spliced into the tow harness on the truck. When doing so you will need to terminate the existing wires from the trucks (Trailer-Tail/LT/RT) as you don't want to back feed the IPM / FCM.
Old 12-04-2011, 09:07 AM
rdr140's Avatar
hate to bring this back up . when wireing a modulite is our trucks a 2 wire or 3 wire ?thanks robbie
Old 12-04-2011, 08:57 PM
rdr140's Avatar
it's fixed
JIROBBI
07-24-2007 09:51 PM
Mechanos
12-21-2004 08:56 AM
Dodgezilla
12-07-2004 09:41 PM
gnarlykaw
08-22-2004 07:52 PM
Amish hauler
04-08-2004 07:07 PM
Quick Reply: trailer wwireing help
