trailer wiring
Old 03-28-2008, 08:46 AM
ian515's Avatar
trailer wiring
do I have to go to dodge for that wierd plug thing that adapts the truck to the trailer wires? or can a buy a wiring harness or what? why did they make it so you have to use that adapter?
man, can you tell I dont tow much?
Old 03-28-2008, 08:57 AM
ian515's Avatar
nevermind, the adapter is only 15 bucks at dodge. I think I can swing that
Old 03-28-2008, 04:27 PM
Busboy's Avatar
Best $15 you'll ever spend, it makes the install a breeze.
Old 03-29-2008, 07:19 AM
Bob H's Avatar
Adaptor won't do much good if the truck doesn't have trailer tow package
Bob H
Old 03-29-2008, 10:07 AM
ian515's Avatar
Bob H
i have the package. I have towed before (just not much with this truck). but I was using someone elses adapter.
Old 03-30-2008, 10:52 AM
Equalizer 2's Avatar
If you are talking for the brake controller, you can get one specifically for the Dodge and certain controllers. I know I got one for my Tekonsha Prodigy and just plugged it into the controller and plugged it into the controller connector under the dash. Less than $20 with the controller and I think they threw it in with my controller.
Old 03-30-2008, 11:04 AM
ian515's Avatar
http://us.st11.yimg.com/us.st.yimg.c...e_1993_2003114
thats what I was talking about.
Old 03-30-2008, 12:18 PM
Mopardan's Avatar
If your talking about the 4 pin flat blade, mine (04) has one hanging down on the drivers side up under the bed from the factory. you might have one too.
Old 03-30-2008, 08:05 PM
You can pick those up a lot of places that have trailer parts. I think I got one at a hardware store (about 3 1/2 years ago) but it hasn't been out of the package yet.
The reason that you have the "round" 7 blade one on your truck is that most of the trailers that these trucks pull use the full 7 pins. Trailer Brakes, tail, backup (also called auxillary), ground, power (to charge onboard battery), left turn/brake light, and right turn/brake light.
The 4 pin that you want only does a ground, tail, left turn/brake, and right turn/brake.
Old 03-30-2008, 09:31 PM
mmm...diesel's Avatar
Does anyone know if there are secondary adapters available to place a second 7 way plug in the bed? I'm not sure why the hell the factory doesn't do this, i hate hanging wires over my tailgate for 5th wheels and goosenecks. I've got the plug to go into the bed, i'm looking for some type of T adapter to put in between the wiring harness and the 7 way on the bumper to put another 7 way in the bed instead of splicing everything.
Old 03-30-2008, 10:03 PM
4x4Freak's Avatar
http://www.etrailer.com/pc-VWH5W~V30137.htm
wyododge
01-13-2009 02:25 AM
Evildiesel
07-02-2006 06:39 PM
charcoal600
04-30-2005 02:34 PM
1320
04-09-2004 09:33 PM
TPilaske
03-13-2003 04:06 PM
Quick Reply: trailer wiring
