PDA
View Full Version : Trailer Wiring..
07Chassis
02-25-2008, 09:20 PM
Im trying to figure out what wires go to the 7 pin plug for my female trailer plug. There is a seperate bundle of wires after I did my upfitting on the 07 cab and chassis that I have left over, I know this is for the trailer wiring and brake control. Any help would be great, I have no clue what colors do what. I guess worst case, I use the light to figure out each wire but that may take a while. I checked the dodge upfitting guide (pdf) and couldn't find anything.
07Chassis
02-26-2008, 06:49 PM
Guess Ill be getting the test light out..
Cummins610
02-26-2008, 08:18 PM
I'll post the guide in a few minutes..........
RH Welding
02-26-2008, 08:21 PM
Always uae a tester to be on the safe side. Most are as followed.
Red-12v hot all time Purple-back ups
Yellow-left turn Big blue-trailer brake
Green-right turn White-ground
Brown-marker kights
Sometimes the brake lights can be black or red. you will almost always have wires left over dont worry about that. If you need a wiring diagram I think I have a copy from a 5500 we put a bed on the other day.
Cummins610
02-26-2008, 08:25 PM
http://i178.photobucket.com/albums/w241/Cummins610/Image3.jpg
ENJOY!
07Chassis
02-26-2008, 10:32 PM
Thank you! You just saved me a lot of time out in the cold tommorow.
DECEPTiON21
01-27-2010, 05:35 PM
ENJOY!
Where did you find that site? I need a wiring diagram for the door ajar wires for power steps. Maybe that site has one?
Colo_River_Ram
01-27-2010, 05:42 PM
Start here:
http://www.dodge.com/en/business/body_builders_guide/
And click to your truck..
Be sure to read all of the info on circuits min & max load rating
Pg 4 of this link shows pto, trailer and up fitters circuit:
http://www.dodge.com/bodybuilder/2008/docs/dcdm/dcdmufwii.pdf
The up fitter circuit can give you more fused power to the truck body and / or trailer if needed, it has a separate fuse block to feed these circuits. It is located on the DS firewall. these are in pdf format so you can save them to your computer
