Trailer Lights
Trailer Lights
Everything comes on fine, but the tail lights and running lights stay on on the trailer after I shut the truck lights off, but not all the time. Sometimes they go off with the shitch somestimes they don't. I checked the voltage at the plug, with the lights off, sometimes theres zero, sometimes theres about nine and a half volts, sometimes theres about a half a volt. ???????????????????
Has anyone ever had this problem?
I assume you have an electronic brake controller. Is it possible there is a bare wire or a cross connect comming from that going to the wiring harness of the trailer?
Also a bad ground will wreck havick and make any diagnostics very difficult. Try making a temporary ground between truck & trailer, a bare wire clamped to each vehicle and see if problems go away, if so look for a bad ground on the trailer or truck.
Just another thought....Don
Whoahoss, by that diagram you are right.....
It's strange, I ust picked up a 7 way plug from a truck and oilfield supply place on saturday and it said right on it, centre pin brakes........
Strange.
Strange.
Are you certain that you're not confusing the 7-pin flat blade Pollock connector that comes on our trucks with a 7-pin round pin connector used on semis and larger commercial trailers? That's a whole different beast!!
Rusty
On the Pollock connector, trailer brakes are at the 7:00 position (pin #2) on the truck plug. The center pin (pin #7) is used for back-up lights.
Rusty
Yep I'm definitely sure as I have round pin Semi type plugs on other trailers, since my stock trailer etc has the fllat pins like a RV I figure I'll wire this one the same.
This plug was labelled centre pin brakes.......
weird.
Very annoying too.
I'm gonna have to check out the way my stock trailer is wired.
Rusty
weird.
Very annoying too.
proudpapa97
05-04-2008 06:50 PM
Amish hauler
04-08-2004 07:07 PM
CHarlan
08-06-2003 08:40 PM
