tractor trailer shift knobs
Old Oct 26, 2009 | 04:34 PM
1bad93's Avatar
tractor trailer shift *****
ive seen it done on two trucks now, and was wondering if any of yous have done this. put a tractor trailer shift **** on your truck. and if you did does it how did you do it? does it bolt right on?
Old Oct 26, 2009 | 05:56 PM
The_Head's Avatar
I drive Peterbilts and I dont see how it could be done. The shift **** has two additional levers to control the splitter and for lo-lo. Plus the ones we have are 4 speeds, so that wouldn't match up either.
What is the point?
Old Oct 26, 2009 | 06:34 PM
EClancy's Avatar
big truck shift ***** belong on the same trucks stacks do.......
big trucks
Old Oct 26, 2009 | 08:19 PM
Tater93's Avatar
big trucks
WELL SAID!!!!!!
Old Oct 26, 2009 | 11:03 PM
faylorz's Avatar
why do stacks "belong" on semis only? i understand why ppl think they are unecesary on pickups but in reality they are unecesary on semis too. plenty of semis out there with the ol turn down underneath
Old Oct 27, 2009 | 01:42 AM
Benjamin b2's Avatar
any shift *** you find will fit on your pickup, cut the stick off, find a bolt that your *** screws into and weld it to the stick, and if your really good, find a nut to us as a jam nut.
my plan is to run my exhaust brake with a the splitter off an eaton fuller, some have one split, some have 2, shoot if im correct im pretty sure there are 3 speeds and 4 speeds, 9,10,13,18, and 15 speeds and **** with hurst, bd, on them, i could see it workin if you put some kind of micro switch in there instead of an air valve. it seems like you guys are to caught up in your own opinion that you cant even answer someones question.
Old Oct 27, 2009 | 07:03 AM
powerrammaster's Avatar
Wow, a little dad vs. son controversy here.Nice.
Old Oct 27, 2009 | 09:52 AM
Mike Mc's Avatar
bad93, I put a chrome Road Ranger **** on my '96 and it doesn't just screw on. Most all tractor/truck ***** are threaded 1/2 NC while the NV4500 had a smaller thread. I used a bunch of tape to make up the difference and it worked OK. The chrome **** would sure get cold sitting in front of the A/C vent.
Beny, the Eaton **** is air operated not electric. How would you activate the exhaust brake with little air lines. You need a electric red **** rear end splitter that mounts below the shifter to activate the brake. This picture of my '68 Power Wagon with a 10 speed shows what I'm talking about.
Old Oct 27, 2009 | 12:34 PM
jk6140's Avatar
big trucks
AMEN!
Old Oct 27, 2009 | 01:47 PM
"Beny" belives you
Old Oct 27, 2009 | 02:38 PM
schamran's Avatar
Don't let them fool you, they fit first gens, and the 4X4 shifter. I know the 4X4 i a different thread, it comes with adaptors. I have a red one on my regular shifter. Need to get another one. They have a white one with a "Cummins Bee" on it too. I should've gotten that one. I know these aren't tractor trailer shift *****, but I think they look cooler. That's just my opinion though. To each his own!
Old Oct 27, 2009 | 02:56 PM
1bad93's Avatar
ok i wasnt trying to start a riot but thanks for the info and them cummins shift ***** are awsome so i think im just gona get me one of thoughs but thanks for help.
Old Oct 27, 2009 | 06:58 PM
Bogie's Avatar
Gear *****
Kool *****
Old Oct 27, 2009 | 07:21 PM
bigdrdge02's Avatar
Where can i order one of those ***** you posted this picture of. those are bad edit
Old Oct 27, 2009 | 07:36 PM
www.genosgarage.com
