track bar conv.
Old 11-28-2008, 08:58 PM
jd green's Avatar
track bar conv.
does any one have pitchers of home made 2nd gen track bar conversion to the 3rd gen track bar
Old 11-29-2008, 12:02 AM
stevenl's Avatar
what exactly is the advantage of going to a third gen??
Old 11-29-2008, 01:48 AM
Fishin2Deep4U's Avatar
2 simple bushings that eliminate the need for a ball type joint on one end. This is the end that wears out the fastest.
Dave
Old 11-29-2008, 10:48 AM
jd green's Avatar
the taperd hole that the ball end goes in is wallered out so it will be easyer to convert it than cut it off the frame and go to the junk yard and get one and weld it on
Old 11-29-2008, 10:07 PM
oldblues's Avatar
hi
you will not believe it is the same truck after you do the 03 upgrade , do it now!
Old 11-29-2008, 10:29 PM
jd green's Avatar
did you biuld your own or just buy the adapter plate
Old 11-30-2008, 11:31 PM
JoeCanuck's Avatar
I went with the Luke's' Link...cheap, easy as pie and works like a charm.
Old 12-02-2008, 10:08 PM
jd green's Avatar
you mean no one has any pitchers of a home made conversion
Old 12-03-2008, 07:50 AM
Racer9's Avatar
I used the Thuren bar http://www.thurenfabrication.com/ you could probably make one like it.
Old 12-03-2008, 08:31 AM
John Faughn's Avatar
I bought mine from Solid Steel .
http://www.solidsteel.ca/
Old 12-03-2008, 08:53 AM
xtoyz17's Avatar
http://lazarsmith.com/science.html
Why bother building one, when you can buy one for such a reasonable price?
Old 12-03-2008, 06:58 PM
TIMMY22's Avatar
Put on a Thuren bar and be done with it for life.
CTD2001
08-22-2009 10:03 PM
Dinner
05-29-2007 02:02 PM
kwillis-a
01-25-2007 09:10 PM
nevrenufhp
06-04-2003 09:20 PM
ejb
03-05-2003 07:01 PM
Quick Reply: track bar conv.
