TPS Trans cable adjustment?
Old 04-25-2006, 09:04 PM
BobQ's Avatar
What is the cable on the TPS for, that goes to the Tranny? The manual sais to adjust it so there is no slack in it. What if I make it tighter or looser?
Thanks Bob
Old 04-27-2006, 02:10 PM
BobQ's Avatar
No takers?
Maybe it is the apps?
Anyway, anyone have any ideas?
Thanks Bob
Old 04-27-2006, 02:21 PM
airman's Avatar
It controls throtle preasure on your trany.If you get it too tight it will not shift till late too loose it will shift too early.
Old 04-27-2006, 02:56 PM
Mcmopar's Avatar
If you get it to loose you will burn things up.
Old 04-27-2006, 05:21 PM
BobQ's Avatar
Thanks guys!
With the Smarty fueling down so low, I would think it would be good to keep it tighter, to keep the pressure up?
Bob
Old 04-28-2006, 07:56 AM
Mcmopar's Avatar
Yes, but if you get it too tight it will not let you shift before you hit the governor.
Old 04-28-2006, 05:12 PM
BobQ's Avatar
I put it pretty tight and no trouble!
When I did my shift kit I did not change any of the shift points. All is well!
Thanks Bob
whosdunit
05-17-2014 08:54 AM
90firstgen
04-13-2008 05:48 AM
Kirk T
09-20-2006 07:19 AM
Crawler
03-02-2006 01:11 PM
hellotbone
10-07-2003 06:54 AM
Quick Reply: TPS Trans cable adjustment?
