Tps ?
Old 07-05-2007, 03:58 PM
Mr. Jimmy's Avatar
Tps ?
My dad's 93 CTD is ocassionally kicking back and forth between drive and OD.
Could it be the TPS or would it possibly be the trans temp sensor?
I had this problem with the 95 and turned out to be the TPS.
Old 07-05-2007, 04:08 PM
If the speedo is steady while this is happening, it's most likely the TPS. The temp switch doesn't kick you out of OD until things are way too hot.
Old 07-05-2007, 07:59 PM
92DIESEL's Avatar
Try adjusting the TPS, after Wanna tweaked mine it doesn't "search" anymore, and with the way it is adjusted right now at WOT it'll hold to 57mph before OD, but driving normal it will shift into OD at 38mph
Life is good now .... Thanks again Dave
Michael
whosdunit
05-17-2014 08:54 AM
Paradise Racing
03-18-2003 06:26 PM
hvanflee
03-13-2003 03:11 PM
feets
01-01-2003 11:04 PM
Quick Reply: Tps ?
