towing with a 94
towing with a 94
Howdy,
I´m aware of the issues dealing with hooking up tail lights with a 94 how you need a special kit or a power module or something to avoid melting your headlamp (which I partially did). Could I skip all that and just run a straight line from my battery to a switch in the cab to the trailer plug? If so, what size fuse should I use? Trailer has 13 small #1895 running lights, plus two brake lights. $90 bucks for a wiring harness is a bit steep. Thanks for any help.
Alex
Alex
