Torx bit size front drive shaft
Old 01-31-2009, 10:49 PM
tnhtractors's Avatar
Does anybody know what size torx bit is needed for the front drive shaft. I need to remove it so I can find that dang grease hole.
Old 02-01-2009, 10:04 PM
ANYBODY ? My #30 torx bit is to small and # 40 torx bit is to big
Old 02-01-2009, 10:40 PM
RTillery's Avatar
Not sure of the size, but make sure you heat the bolt/flange area up enough to help the loctite let go. If you warm it up good, the bolts remove easily, if not, you are going to twist the sockets out of the bolt. I replaced mine with hex heads. Good luck.
Old 02-02-2009, 07:03 AM
Swayse's Avatar
I thought it was a #45, but I'm not sure. I replaced mine with hex nuts also, I hate torx.
Old 02-02-2009, 08:00 AM
mastercaster's Avatar
here is a thread that may help.
http://www.cumminsforum.com/forum/3r...ive-shaft.html
Old 02-02-2009, 08:39 AM
XLR8R's Avatar
You need a long reach T40.
Old 02-02-2009, 08:52 AM
titoheadfaceman's Avatar
x2. It is a 40. Maybe your 40 wasnt make correctly or something like that.
Old 02-02-2009, 09:34 AM
XLR8R's Avatar
... and the 40 isn't tight.
Joes truck
06-02-2007 11:09 PM
broncobilly
03-17-2007 12:03 AM
04ctd
11-25-2006 07:30 PM
jeeptjstud
12-14-2005 05:15 PM
Quick Reply: Torx bit size front drive shaft
