torque
Old 05-08-2011, 03:13 PM
beegiedog's Avatar
Smile torque
Hi,
Could anyone give the tourque specs. on the hold down screws for the injectors?
Thanks,
J.R.
Old 05-08-2011, 03:22 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
What year?
Old 05-08-2011, 03:24 PM
Cummins Guru
BigIron70's Avatar
03 and up common rail 5.9
Install fuel injector holdown clamp (mounting flange) bolts. Do a preliminary tightening of these bolts to 5 N·m (44 in. lbs.) torque. This preliminary tightening insures the fuel injector is seated and centered. After tightening, relieve bolt torque, but leave both bolts threaded in place.
If required, assemble o-ring to injector fuel supply connector. Lubricate connector bore and threads. Install fuel supply connector into cylinder head by engaging locator into groove and push to engage o-ring. Install fuel supply connector nut (fitting) into cylinder head. Do a preliminary tightening of this nut to 15 N·m (11 ft. lbs.) torque.
Perform final tightening of fuel injector mounting clamp bolts to 10 N·m (89 in. lbs.) torque.
Perform final tightening of fuel connector nut to 50 N·m (37 ft. lbs.) torque.
mitm
08-16-2009 09:29 PM
Firstgenfanatic
05-14-2008 06:17 PM
mainer
07-17-2007 07:13 PM
PapaSmurf
12-19-2003 02:14 PM
Davidp
02-01-2003 05:49 AM
Quick Reply: torque
