Torque specs
Old 11-21-2010, 04:18 PM
454 no more's Avatar
Torque specs
Anyone know the torque spec for the tranny mount on a w250 automatic? I just replaced mine, toured it to 50 ft lbs and the truck shakes like crazy.
Old 11-21-2010, 04:22 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
that's enough torque for those bolts. you may have other problems. Do you have a two piece driveshaft?
Old 11-21-2010, 04:30 PM
It's a one piece driveshaft that was just balanced. The truck shakes in park at idle, is worse in gear and gets better with rpm. It started when I replaced the tranny mount.
Old 11-21-2010, 04:46 PM
justin mcfall's Avatar
Did you use Rubber or poly mounts? I put poly in my 90 W250 and it vibrated like crazy...
Old 11-21-2010, 04:49 PM
There rubber, I'm thinking 50 ft lbs is too much?
Old 11-21-2010, 05:02 PM
Cummins Guru
BigIron70's Avatar
What RPM does it smooth out? Did you have trans out recently? We are talking about 5.9 CTD here right? What year? Is it 4X4?
Old 11-21-2010, 06:03 PM
1993 4x4 cummins, reg cab longbow .
Old 11-21-2010, 06:44 PM
dkimmel's Avatar
Make sure the mount is the same height. Maybe it 's different causing something like the exhaust to touch the frame.
Old 11-21-2010, 07:49 PM
I checked everything underneath, seems fine. It started right after I changed the mount. I noticed the difference as soon as I started the truck on the hoist. The mount was originally tightened with an impact , I loosened it off to 50 ft lbs and it got better. 50 ft lbs is the torque spec for manual trucks, I'm justvwondering if the automatics are different?
lniemeyer2
10-24-2012 12:11 PM
06RAMCTD
0
12-19-2006 04:15 PM
docwes
06-02-2003 11:01 AM
MnTom
05-16-2003 09:08 PM
Lary Ellis (Top)
02-23-2003 01:10 PM
Quick Reply: Torque specs
