torque converter lockup engaging all the time!
Old 04-25-2004, 12:39 PM
Jambbii's Avatar
Its like I have my lockup switch on all the time! It started yesterday when I was screwing with wiring under the dash for my stereo, I was moving some wires around and I heard something ground out real quick but my stereo reset so I thought it was that grounding out. I drive the truck and the lockup is on all the time. I figure I messed up my lockup switch check everything with that, I even unplug it from the computer and the converter is still going nuts.
Any suggestions?
Old 04-25-2004, 07:33 PM
j-fox's Avatar
Keep checking!! Something is grounding it.
It must be external to the trans.
Old 04-25-2004, 09:00 PM
Crimedog's Avatar
It's got to be under the dash, maybe you knocked a wire off?
Old 04-26-2004, 06:06 PM
Jambbii's Avatar
Well I found the problem. I have the B.D. transmission with the pressure lock system . Any ways it is wired into the fuse box of an accesorie and when I grounded something out it blew the fuse on the wire. The thing that threw me off was that from the outside the fuse looked fine. So I started checking voltage and there was none and sure enough the fuse blew,
Old 04-26-2004, 08:44 PM
Crimedog's Avatar
Isn't it funny how it is always the last thing you check?
Good to hear you got 'er figured out.
Old 04-27-2004, 06:58 AM
j-fox's Avatar
When I find the problem, I quit looking!!!!!!!
Old 04-27-2004, 10:37 AM
BIG&BAD's Avatar
i would hope so
Old 04-27-2004, 02:31 PM
phox_mulder's Avatar
Since problem is fixed, moving this out of "help".
phox
93dieselZak
06-16-2011 06:10 PM
th_racer
03-05-2005 10:30 PM
tomh
02-14-2005 08:26 PM
tractor-man
10-13-2004 02:54 PM
Jambbii
10-18-2003 07:08 PM
Quick Reply: torque converter lockup engaging all the time!
