Tires
Old 04-16-2004, 07:12 AM
1ST CUMNZ's Avatar
Tires
How big of a tire can you out on stock chrome wheels (94-99).I need to buy some (4 new tires) this is going to hurt.I would like to put a taller tire on the truck.Reason being alot of space between fender lip and tire,has always looked a bit odd
Old 04-16-2004, 07:57 AM
AlpineRAM's Avatar
I'm running 255/85R6 BFG Mud Terrain.
You'll have to get a spare in the same dimension because with a smaller wheel on one side you'd either burn up your limited slip differential (rear axle) or have the steering of a BSE cow on ice if on the front axle.
AlpineRAM
Old 04-16-2004, 08:49 AM
berner's Avatar
Originally posted by AlpineRAM
..... have the steering of a BSE cow on ice if on the front axle.
AlpineRAM
I run 265/75 BFG AT's. They're about 30 1/2" tall, close to a 235/85. I looked at the 285's but thought they wouldn't look right on a 6 1/2" wide rim.
Old 04-16-2004, 11:05 PM
wagontrain131's Avatar
I run 285 Toyo Open Country tires. I'm going to back down to a 265 next time. Not that they are causeing any problems (plenty of room) I just can find any "E" Rated at that size.
Old 04-17-2004, 10:24 PM
farmer dave's Avatar
I know what you mean. My truck right now has 265/75 and they look small. My 97 had 285/75 and they looked good. As far as the E rating goes, just look at what weight they are rated to. Some of the D are rated to a E rating.
Old 04-17-2004, 10:38 PM
torquefan's Avatar
305/75R16 will fit, but look a bit odd on that narrow a wheel. 285's don't look too bad. The 305's seem to be just the right size to fill that wheel well though.
Old 04-18-2004, 12:32 AM
SjLingenfelter's Avatar
ProComps ATs 305/70/16 dont look goofy onthat size rim.
Old 04-19-2004, 07:29 AM
1ST CUMNZ's Avatar
Thanks for all the info gents.I'am going see if i can track down some 265-85-16.I think it should fit on the wheel nicely and fill up
the gapping hole between the fender and tire.
Old 04-20-2004, 11:22 AM
I have 265 right now and there still is a big gap. I would go bigger, atleast 285.
chrisminx
07-07-2010 06:48 PM
1320
05-29-2009 10:24 PM
sakisaki400
23
12-31-2006 10:17 PM
Captain
09-09-2005 12:16 AM
Quick Reply: Tires
