Tires...not wanting the off-road look
Old 09-30-2008, 08:01 PM
you da man's Avatar
In the next 2-3 months I'll be getting some new tires...Cooper Zeon LTZ (I like the look of the lugs on the sidewall). I'll be putting them on 20x9 or 20x10 wheels. My 07 Mega Cab is at stock height so I'll be leveling that at the sametime. I'm liking the idea of the 305/55/20 size but could I get away with the 275/55/20 or would that be too small looking on the Mega Cab. Thanks for any input, I'm open for suggestions with the backspacing on the wheels as well.
Old 09-30-2008, 09:07 PM
hivoltage's Avatar
I'm confused, you're going to level the truck and add off road style tires but your title says "not wanting the off-road look".
As far as tire size I'd go with the 305's, IMO the 275's would look too small.
As far as the best backspacing I think someone else here may be able to help you better than I could.
Old 09-30-2008, 09:12 PM
jamesbfishin's Avatar
A 305 is a good all around tire size, fills the wells a bit better, but still small enough to give close to stock performance.
For wheels, if you go with a 20x10 be prepared for rubbing issues, a 20x9 with as close to 6" backspacing will be your best bet, check my sig below to see what I'm running.
Old 09-30-2008, 09:14 PM
you da man's Avatar
I should have said, not looking for a look that involves a 17" or 18" wheel with a 33" tire with all that sidewall. I've even toyed with the idea of 22" wheels but worried about load capacity of the wheels and/or tires, especially if I go with a 305/40/22. I would'nt mind keeping the stock front height and lower the back but haven't found anything that would lower the rear of the truck to level it in that manner. Plus lowering is pretty much going to make for a harsher ride, I've did the low rider truck thing back in the late 80's, early 90's and even with the right equipment you still bounced everywhere.
Old 09-30-2008, 09:17 PM
There are 3 small "shims" between the rear leaf pack and the axle, you could remove them to drop the rear, just have to check the threads on the ubolts to make sure they don't bottom out before tightening to the axle. Factory spring is unchanged so the ride will be no different, just increase the chance of hitting the bumpstops with a HEAVY load.
Old 09-30-2008, 09:55 PM
Danderson's Avatar
Thumbs down Ricer rims.
Less sidewall than stock=pimp. Better handling I suppose,but rougher ride and more apt to damage the rims if you hit a bump. I don't understand the ricer factor on diesel trucks.
Old 09-30-2008, 10:28 PM
you da man's Avatar
I understand what you are saying. Most people who buy diesels buy them for work and play. I bought mine because I drive 3k-4k miles per month and pull my boat or enclosed motorcycle trailer a few times per month as well. I wanted the diesel for longevity, mileage, and reliability. I'm not going for a ricer look though, then again I'm not going for a Billy Joe Bob redneck hick look that comes from a place where men are men and sheep are nervous that has a sticker on their truck that says "cowboy up" or some bull *********. To each his own, I can respect that, just looking for advice that's all. I'll probably just stick with the 20x10 with 305/55/20.
Old 09-30-2008, 10:40 PM
hivoltage's Avatar
I got ya, makes sense, I was just confused....happens to me all of the time!
Old 09-30-2008, 11:13 PM
Evil Genius's Avatar
These are 305/55's on 20X10 wheels with a leveling kit. I think the bs is 5.5.
Here's one without the flares:
Old 09-30-2008, 11:31 PM
Fisherguy's Avatar
I agree.
I don't see why you'd want 2" sidewalls on a 4x4...
... and I don't have ********* or a "cowboy up" decal on my truck either!
Old 10-01-2008, 12:56 AM
apprentice's Avatar
i love my toyos, wear is fast but drivability rocks... they throw big rocks
Old 10-01-2008, 10:47 PM
Eddy Reyes's Avatar
That was funny!
Here you go: (My next tire) 305/60/20 E rated 3,415
http://www.goodyeartires.com/goodyea...0&sidewall=BSL
Old 10-02-2008, 12:04 AM
BroncoHound's Avatar
Originally Posted by Fisherguy
I agree.
According to his signature, the guy who is asking the question has a 2wd pickup.
Just cause it's a diesel doesn't mean it has to be a mud-bogger, guys. If a truck owner spends the vast majority of his time on the highway and doesn't pull GCVWR-type loads, I don't see the problem.
bandit1trucking
02-14-2019 08:16 AM
1320
05-29-2009 10:24 PM
Onemoparnut
08-17-2008 09:39 PM
sakisaki400
23
12-31-2006 10:17 PM
Mule Skinner
11-16-2002 06:57 PM
Quick Reply: Tires...not wanting the off-road look
