Tire size
Old 06-17-2007, 09:32 AM
ccraver's Avatar
Tire size
I know this question has been asked before but I could't find the thread. I want to put some 315's on my factory wheels but i don't want to put a leveling kit on unless absolutely necessary. Will I have problems with them rubbing? If I do put a leveling kit on will I need to have the truck realligned and will I need to get longer shocks. The local lift shop here says you don't need to do anything but put the coil spring spacer on and thats it, but I've heard different. And also will I need some different gears if I'm running 373's right now? Any help would be appreciated. Oh and any opinions about the quad box? A guy here locals got one for $150.
Old 06-17-2007, 12:32 PM
ccraver's Avatar
Anybody have any input on this? And does anybody know if you can adapt a quad box from an 05 to fit a early 04?
Old 06-17-2007, 02:11 PM
Luvnacumns's Avatar
Yes you can run 315 without a leveling kit on stock rim's I did it for a while. They will rub slightly on the control arms but other than that you will be fine.. If you level it you will need it aligned. No you won't need different gears. I've ran 37's on 3.73's with no problems!!! You'll have to ask quad but If nothing you can send it in to update it!!
Shane
oldwhite12v
03-25-2011 04:28 PM
schoust
10-21-2009 10:09 AM
bigdogtruck
18
11-21-2007 08:09 PM
4RnrRick
02-27-2007 11:25 AM
ValkSmile
01-23-2007 11:42 AM
Quick Reply: Tire size
