Tire size question
Old 08-14-2009, 08:26 PM
Ceno's Avatar
Tire size question
I have seen 37 with no lift and I found 40's with 3" kore so should I clear 40's with 5"?
http://www.dieselpowermag.com/featur.../photo_06.html
Old 08-14-2009, 09:38 PM
bansh-eman's Avatar
You probably ging to have to do some cutting with only a 5in. And depeding on the width and backspacing of your wheels, your going to have some rubbing on the control arms.
Old 08-21-2009, 10:20 PM
Catmandoram's Avatar
Won't fit without rubbing on the inside back wall. I wouldn't do a 5". Your not going to like it unless it's just a street wheeler but even then.
Old 08-22-2009, 12:12 PM
Ram Daddy's Avatar
Wink
Those 40s are on stock Power Wagon rims , so I`m SURE they rub the control arms when turning , and they used some Bush Wacker cut-out flares designed for a Ford Superduty...look closely at how they fit (or DON`T FIT) the body lines and go over the headlights. I`m sure the hacked the fenders all to snot under those flares , as there`s not much metal at the rear of the front fenders to begin with , which is why they don`t make them for the Dodge 3rd gens.
You`ll need at least 9 in. of lift to clear 40s even on a street truck without major fender cutting...or glass pre-runner style fenders.
oldwhite12v
03-25-2011 04:28 PM
bigdogtruck
18
11-21-2007 08:09 PM
mkeanglorldo56
11-04-2007 12:34 PM
4RnrRick
02-27-2007 11:25 AM
ValkSmile
01-23-2007 11:42 AM
Quick Reply: Tire size question
