Tire questions
Old 03-20-2006, 07:56 AM
dieseldon's Avatar
Tire questions
Well, time to buy some new tires, and was thinking of going from the 265's to a 285 tire. Now the question I have is do the 285's come in an E rating? I was told that to have the E rating, I cannot get the 285's. Now is this true, or did was thia dealer just blowing smoke?
Old 03-20-2006, 08:20 AM
RickCJ's Avatar
You can find this info on the internet!?!
I do not know of any tire companies making a 285 E ply tire.
Old 03-20-2006, 08:44 AM
VACHZHD's Avatar
I don't think there is much selection... but BF Goodrich makes their 285/75/16 T/A KOs in an E rating... Merchant's Tire told me they can get them. Haven't ordered any yet, still waiting for the current set of load range D's to wear out.
Here's a link that supports their existance:
http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf
Old 03-20-2006, 08:50 AM
dieseldon's Avatar
DUH!! Stupid me,I could have found that out. Guess its a Monday thing! Thanks for the replys!
Old 03-20-2006, 07:20 PM
BIGROD's Avatar
The 255/85R16 is about the same height as the 285/75R16, just narrower. The 255 maybe easer to find in E load rating.
Just a thought
Old 03-27-2006, 01:58 AM
Katmandu's Avatar
Thumbs up
The door placard says "E" Load, but high LOAD INDEX/CAPACITY "D" Range tires will work just fine.
Be sure to match up the Load Index with your GVWR and tow ratings for your particular truck.
Here's a Load CAPACITY chart for you.
http://www.discounttire.com/dtcs/infoLoadIndex.dos
I'm buy Load Range D Revos tomorrow in a 285/75-16s. They have a Load CAPACITY of 122. 122 is rated at 3307lbs PER TIRE.
My trucks front axle is rated at 4600lbs and the rear is 6000. My new tires will have a Capacity of 6607lbs PER Axle.
FYI, Load Range D ends at 122 and Load Range E Range starts at 123.
Also, Load Range D tires are 8 PLY whereas Load Range E tires are 10 PLY.
Dave88LX
09-01-2011 11:36 AM
4RnrRick
02-27-2007 11:25 AM
I PASS GAS
05-12-2006 11:19 PM
FrankB
08-17-2004 12:27 PM
dieselcrazy
09-30-2003 06:39 PM
Quick Reply: Tire questions
