Timing without timing pin?
Old 10-11-2011, 04:41 PM
mechmagcn's Avatar
While setting the valves a few days ago I discovered that the PO had broken the timing pin, is there a way to set the pump timing without the pin? I have the dial indicator, adapter and puller, just no way to locate TDC.
Old 10-11-2011, 11:20 PM
Tate's Avatar
Use the drop valve method to find TDC and mark the balancer. You'll need a dial and mag base for this.
Old 10-12-2011, 10:00 AM
infidel's Avatar
I've yet to find a timing pin that's accurate enough to set the timing, good enough for valves though.
You'll find instructions on the drop valve method in the engine section here> http://www.cumminsforum.com/forum/94-98-tech-articles/
Old 10-12-2011, 10:29 AM
mechmagcn's Avatar
Thanks, I'll try this method.
DevilzTower
03-21-2011 11:37 AM
shibbyman22
09-12-2010 09:32 PM
Skip H
05-21-2010 06:30 PM
JaimeG
03-26-2009 06:58 AM
Crimedog
03-11-2004 01:54 PM
Quick Reply: Timing without timing pin?
