Timing
Old Mar 25, 2006 | 01:36 AM
Teddy Bear's Avatar
Timing
Planning on getting my truck timed here in the near future. My truck has a slight miss/pop when it gets up around 2500rpm or so, kinda like its starving for fuel. Ive heard other 160pumped trucks do the same thing. Some have told me that advancing the timing to 20* is about the only way to stop it, but I was thinkin that was a little high. Just lookin for some input on what yall think would be best for me. Thanks
Josh
Old Mar 25, 2006 | 01:40 AM
cumminsdriver635's Avatar
Id sell it
Eric
Old Mar 25, 2006 | 01:58 AM
Teddy Bear's Avatar
Originally Posted by cumminsdriver635
Id sell it
Eric
......and get a PowerStroke Dont let eric fool ya, hes really a closet PowerStroke man!!
Old Mar 26, 2006 | 05:16 PM
Teddy Bear's Avatar
Bump.....
Old Mar 26, 2006 | 05:24 PM
I think for what u are doing 16 or 17 degrees........
Eric
Old Mar 26, 2006 | 05:37 PM
Willy91's Avatar
I'd try 16-18*.
Old Mar 26, 2006 | 07:22 PM
TxDiesel007's Avatar
Eric
Smaller pumps usually do better with higher timing
Depending on mods, maybe the truck will do better with 17-19 maybe?
Rick
Old Mar 26, 2006 | 09:59 PM
Crimedog's Avatar
I'm at 16.5 and it's pretty smooth. It really depends on how much more fuel and boost you want to throw at it. If you're looking at keeping your stock turbo and less than 38 psi or so you could probably get away with 17-18, but if you're going to run more boost than that or maybe water meth injection you want to keep it closer to 16.5 or so to save your head gasket. If you are just going to do your plate and DVs, IMO you can run about 17.5 or so maybe a hair more. Then if later you want to add more boost and fuel, you can drop the timing a bit.
good luck
GR40RCapri
Jul 24, 2006 11:47 PM
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
