TIMING
TIMING
CAN ANYONE EXPLAIN TO ME HOW HARD WOULD IT BE<br>TO BRING THE TIMING ON MY TRUCK UP TO 16 DEGREES.<br>I'VE PHONE A COUPLE OF DIESEL EXPERTS
.I CAN'T SEEM TO GET A STRAIGHT ANSWER.<br>PLEASE HELP
Re:TIMING
If you are mechanically minded, then setting the timing is pretty straight forward. Having said that, you will need a set of timing tools to do the job. Snap-On sells a set under the part number SP500. If you don't have a factory service manual, Dave Fritz has the instructions on his web site:<br>http://dodgeram.info/tsb/1994/18-10-94a.htm<br><br>Note that you will have to determine the pump plunger lift for your model year. Good luck, Marc
Re:TIMING
Piers has a lift chart on his web site. The tools and TSB that MDKram refers too are what I used and it is a lot easier that it seems. Depending where you are located you may find someone in your area that could help.<br>Bruce
Re:TIMING
I heard there was a small **** in the side of the pump housing. You just turn it up or down depending on what power level you want. I think it is marked in HP increments from 200-1000.<br><br>Dail your way to happiness
I have never looked , but was told this by Dr Performance.
I think a bunch of other guys were too.
<br><br>Don~
<br><br>Don~
Re:TIMING
Well I have a 4k gov kit on my truck and I decided to tighten the gov springs down a little more so that I could hit 4600 rpms ;D Yeah yeah your going to blow you engine. Well Its my money and I like it. One problem. what is the highest I can bump my timing up to with the stock head gasket? I have heard 19 was a good place to put it and thats where I plan on timing it to unless anyone can think of reason why not.
DM01
DM01
Re:TIMING
[quote author=dodgeman01 link=board=16;threadid=15774;start=0#149387 date=1055645637]<br>Well I have a 4k gov kit on my truck and I decided to tighten the gov springs down a little more so that I could hit 4600 rpms ;D Yeah yeah your going to blow you engine. Well Its my money and I like it. One problem. what is the highest I can bump my timing up to with the stock head gasket? I have heard 19 was a good place to put it and thats where I plan on timing it to unless anyone can think of reason why not.<br>Thanks<br>DM01<br>[/quote]<br><br>Aaron I can think of TWO good reasons........#1 it was Scott that told you 19* timing, but he also said that his friends who's truck they were working at Muncie had blew 2!! head gaskets!<br><br>#2 knowing how you drive!
Re:TIMING
[quote author=dodgeman01 link=board=16;threadid=15774;start=0#149647 date=1055735936]<br>I'm still looking for some so called fuel screw
<br>DM01<br>[/quote]<br><br>So is my cousin thanks to talking to you......... :
Re:TIMING
[quote author=Got Smoke? link=board=16;threadid=15774;start=0#149660 date=1055738266]<br>[quote author=dodgeman01 link=board=16;threadid=15774;start=0#149647 date=1055735936]<br>I'm still looking for some so called fuel screw
<br>[/quote]<br>Tell his ugly mug to come up here and we can tweak that pump up until he looks like schides pulling truck. only with fire
Speaking of Scheid. you need to come up to their pull this summer.<br>DM01
Re:TIMING
[quote author=dodgeman01 link=board=16;threadid=15774;start=0#149671 date=1055739703]<br>[quote author=Got Smoke? link=board=16;threadid=15774;start=0#149660 date=1055738266]<br>[quote author=dodgeman01 link=board=16;threadid=15774;start=0#149647 date=1055735936]<br>I'm still looking for some so called fuel screw
Speaking of Scheid. you need to come up to their pull this summer.<br>DM01<br>[/quote]<br><br>More than likely will considering I don't have any of the female persuassion holding me down here....although I think I'm working on one
;D she's gotta ditch her loser b/f first though
sound familiar :
sound familiar :
Re:TIMING
yeah those dang BF's can be a pain to get around. :'( just keep trying man Heck I never give up. and no I'm not getting married like Ricki said.
I'm not ready to be tamed. well there is this one girl who could if she wanted but don't let her know that
<br>DM01<br>
<br>DM01<br>
