timing of Injection pump
Old 08-07-2010, 10:32 AM
Knot Magic's Avatar
I've got a 2000 - 3500 dually that I bought with a injection pump thats been replaced. I really don't think it's got the giddyup and go that it should have. My question is, is there anyway to check timing ?
Old 08-07-2010, 01:42 PM
johnh's Avatar
the timing is controlled by the ECM.
other than that maybe the key on the vp44 shaft is wrong
Old 08-07-2010, 02:54 PM
Knot Magic's Avatar
Thanks for the reply, what are the chances of the ECM going south? Anything else I should look for?
Old 08-07-2010, 04:30 PM
Junk Man's Avatar
I just got done installing a VP twice. 1st was either bad out of the box or taken out by bad fuel. Both installs went easy as pie.
The key comes from the rebuilder with numbers that match the pump. MWFI sends their key installed correctly with the arrow pointing towards the pump. You have to be not paying attention to screw it up. You could pull the front cover to make sure everything is aligned correctly but I'd look elsewhere.
Got any codes?
tommurray
02-23-2014 10:38 AM
blueberry
11-02-2005 11:06 AM
ViperSBT
06-21-2005 06:22 PM
JMAHAN
08-18-2004 02:33 PM
Quick Reply: timing of Injection pump
