timing bump....throttle stuck
Old 08-10-2011, 05:37 PM
hounddogks76's Avatar
Ok guys, i finally did the timing bump. Went an 1/8th inch, but the problem is that my throttle is catching n the main fuel line now, since the fuel line is pinched between the head and the pump. I didn't wanna try and bend the fuel line out of the way, until i talked to you guys first...is there a trick to this? I searched and didn't see anyone else run into this problem.
Old 08-10-2011, 05:47 PM
Onemoparnut's Avatar
I had to bend my supply line when I movement the throttle linkage and removed the high idle screw. Mine is a little different though because it is intercooled. Can you take a picture to help show exactly what is going on.
Old 08-10-2011, 05:51 PM
Thanks onemoparnut....i'll try that...just wanted to make sure first...haha Currently without a camera, i'll post if it works.
Old 08-10-2011, 06:28 PM
Ok..the stars have once more been aligned...lol Tweaked the main line and it works just fine now!
Old 08-10-2011, 07:29 PM
Sweet!
Old 08-10-2011, 08:25 PM
I will say this much for the adjustment....the turbo lights alot quicker now...less smoke and alot more whistle!
Baja
01-29-2008 08:17 PM
royta
11-06-2006 08:19 AM
LCH
10-26-2006 05:10 AM
GR40RCapri
06-25-2006 12:53 AM
LanceD
10-25-2005 11:16 AM
Quick Reply: timing bump....throttle stuck
