Tie Rod Ends on an '03 Caravan
Old 10-17-2004, 09:11 PM
MnTom's Avatar
Angry Tie Rod Ends on an '03 Caravan
Has anybody got any experience with the tie rod ends on an '03 caravan? Wife's van has had a "rattle" in the front end for quite a while. I rotated the tires and found out the tie rod ends are sloppy. This van only has 16,799 miles on it. She needs to take it in for a power steering hose recall, so I was thinking of having the techs look over the front end to see what they find. I don't want to say anything so I can see what they are like (first time dealing with them). Will I be told "wear item-not covered by warranty"? I don't think that there should be any noticible wear with less than 17k miles on.
Tom
Old 10-17-2004, 09:44 PM
amartinson's Avatar
Wear items are usually only belts, tires, brakes and the like. I would ASSUME that suspension components would be covered. That seems very odd for such low mileage. Maybe there is an updated part.
Old 10-18-2004, 05:23 PM
MnTom's Avatar
Well Andy, I will find out more next monday. That is when it goes in for the recall and to check the front end.
Old 10-25-2004, 06:03 PM
MnTom's Avatar
Wife took the van in and guess what..................... Two new outer tie rod ends, and new bushings for the sway bar. Alignment too. WARRANTY!!!!! Wow was I surprised!!!
ddestruel
12-07-2008 06:37 AM
blafleur
10-23-2004 03:04 PM
doug
05-24-2003 08:55 AM
powerwagon440
05-01-2003 05:20 PM
Quick Reply: Tie Rod Ends on an '03 Caravan
