"ticking" noise
Old 11-14-2003, 08:41 PM
Mostwanted's Avatar
"ticking" noise
I have been hearing a slight ticking noise coming from my engin. I never noticed it before. To me it sounds like a dead lifter in a 350chevy. Anyone have a guess as to what it could be?
Old 11-14-2003, 08:49 PM
Re:"ticking" noise
A "bomb"?
Seriously, though, when was your last valve adjustment? Too loose and it will tick.
Old 11-14-2003, 11:33 PM
BigBadDodge's Avatar
Re:"ticking" noise
Lay under the truck, beneath the drivers seat, while it is runing and see if it is more pronounced could be the fuel return line.
BBD
Old 11-15-2003, 05:22 AM
berner's Avatar
Re:"ticking" noise
Have a look at the overflow valve on the injection pump. Might be an injector too.
Old 11-15-2003, 09:22 AM
Smokee's Avatar
Re:"ticking" noise
I second berner on the overflow valve.
Old 11-16-2003, 05:49 PM
Cummnzpowr's Avatar
Re:"ticking" noise
it also could be lift pump...however right after i put a new one in, it started ticking again, {only at idle though}..so who knows ..good luck :-
Old 11-16-2003, 06:19 PM
Captain's Avatar
Re:"ticking" noise
I hear the ticking at cold idle too. I always just thought it was the check valve.
Chris
Old 11-16-2003, 06:40 PM
RCW
RCW's Avatar
Re:"ticking" noise
My guess is that it is the transfer (lift) pump. See if you can get a mechanic's stethoscope and listen to the pump. Also, listen to the overflow valve on the inside of the injection pump.
If it is the pump, when you replace it, be absolutely certain that you fill it with light oil before you install it, and then again make sure you have diesel running through it before you hook up the outflow line. If you try to prime the pump when it is dry, you will erode the piston and it will start ticking again in a few weeks to months.
If it is the overflow valve, check for a broken checkball spring. That is the spring under the first hex on the assembly.
Old 11-16-2003, 06:46 PM
Eat Beef's Avatar
Location: Alberta Foothills - Power to grow with 6 in a row - XLR8
Re:"ticking" noise
Sorry I don't have an answer for you but I'd also like to know what that ticking noise is. In my case it sounds like it's coming from midway back, driver's side, between cab and box. ?????
Andy
Old 11-17-2003, 08:26 AM
winner172's Avatar
Re:"ticking" noise
I chased the phantom ticking noise in mine when I first bought it. Replaced lift pump and overflow valve and it still ticks. I've just decided to live with it. On mine it resonates in the fuel tank. If you put your ear up to the tank or take the fuel cap off and listen it is very pronounced and sounds like a check valve checking. Thats probably what it is.
Old 11-17-2003, 08:50 AM
QUICKMCSS's Avatar
Re:"ticking" noise
[quote author=Eat Beef link=board=16;threadid=22443;start=0#msg210304 date=1069030013]
Andy
[/quote]
My truck sounds the same way. I can not find were its coming from.
Old 11-17-2003, 06:45 PM
ridofpwrstroke's Avatar
Re:"ticking" noise
Same with my 98. It ticks right between the cab and box.
Old 11-17-2003, 10:41 PM
Re:"ticking" noise
Takes a licking and keeps on ticking ;D
Old 11-18-2003, 01:01 AM
Eat Beef's Avatar
Re:"ticking" noise
You're right BigBadDodge. I've decided it's not worth the worry.
Andy
Old 11-18-2003, 07:32 AM
Re:"ticking" noise
Mine did it for over four years !!!
BBD
Quick Reply: "ticking" noise
