ticking noise only when hot?
ok so i get this ticking noise only when the truck is fully warm. it looks as though my fan is a little bent and there is 1 fin that has a small piece missing from it about 1/2inc by 1/2 inch. has anyone had this happen or have a similar sound? its pretty loud i can hear it with the hood closed when im outside the truck
i dont think it is an injector, the oil is not overfull and it is not the valves i just adjusted them. it has been doing it since before i adjusted them i just thought i should try adjusting them to make sure it wasnt the valves. what could it be? thanks
no you have to adjust the valves it is easy so i did it just thought maybe i had a couple loose ones and they were at about 75k not real bad but now they are tight and within spec
1985cucv
04-11-2010 10:42 AM
Strjock81
16
12-12-2007 09:53 AM
duallydave
08-07-2005 09:38 PM
