Thuren Track Bar
Thuren Track Bar
Does any one know how to set one up. I know under full spring compression that the axel moves toward the passinger side so with a 2 inch leveling kit the axel will be setting 1/2 inch to the drivers side .now having said that how do you determan how much to adjust it over so it does not run off the axel bump pads under full compression. if you go to far it will crash into the axel housing .I would really like to now this before I buy one .thanks
With +2" of ride height, it doesn't move far enough at full compression to miss the bumps.
Adjust it so that the axle is centered at ride height.
CTD2001
08-22-2009 10:03 PM
silkywoods
17
12-03-2007 05:09 PM
getblown5.9
25
12-08-2005 11:52 AM
