thuren trac bar?
Old 01-27-2008, 01:08 PM
mike moore's Avatar
thuren trac bar?
just installed my carli 3" lift. looks and sits real nice.It does look like the front axle is sticking out a little to the left of the truck.what point on the truck should I take measurements to see if the axle is off center or if its my imagination? once I install a adjustable trac bar is it gonna set my toe out again and need another alignment? Has anyone tried solidsteel bars or is Thuren,carli,or kore the way to go.
Old 01-27-2008, 02:08 PM
bob4x4's Avatar
Carli also sells the Thuren bar,should have done it when you had the rest installed.
Bob
Old 01-27-2008, 03:28 PM
trx
trx's Avatar
at what lift size would you see benefits from a thuren track bar?How easy is it to set up properly and is there a recommened camber/castor angle to give to the local alignment shop for best ride or will they just follow factory specs
Old 01-27-2008, 04:32 PM
bob4x4's Avatar
About 2" and up will be measurible.Camber is not adjustable with out going to off set ball joints
Bob
Old 01-27-2008, 05:03 PM
mike moore's Avatar
Installing it is no problem ,just not sure where to measure from to get it perfectly lined up or does the alignment shop need to do it.
Old 01-27-2008, 05:38 PM
rjm022's Avatar
with 2" inches of lift you we need to extend the trac bar about 1/4 inch longer. so, with three inches of lift i would start around 3/8 of an inch longer and then take measurements of your axle on each side of the truck.
Old 01-27-2008, 11:03 PM
BigGameJames's Avatar
Would a trac bar help me out or no?
Old 01-27-2008, 11:25 PM
chipmonk's Avatar
i'm sure your lift kit came with a relocation bracket that re-centered your axle, but don's adjustable track bar is a much better piece than stock, and has much better bushings. it's not a necessity, but especially with the lift and tires, it could only help.
Old 01-27-2008, 11:43 PM
firemansdiesel's Avatar
Adjust the Thuren Trac Bar to 39".
Old 01-29-2008, 07:35 AM
mike moore's Avatar
thuren trac bar?
No relocation bracket neccessary,it was only springs and shocks.Icalled carli ont the trac bar he said 39 and 1/4" should do it eye to eye.BTW,I put the 2 extra leaf spacers back in the truck,front measures 42" up front and 43"in the rear from the ground to the fender.looks real sweet.
Old 01-29-2008, 10:52 AM
XLR8R's Avatar
The trackbar needs to "grow" ~.030" longer bolt C-C for each 1" of lift to keep the front axle centered under the frame... if you don't want to buy an entire bar, we offer offset trackbar bushings for lifted trucks.
Old 01-29-2008, 06:58 PM
mike moore's Avatar
thanks for the info,i got a solid steel waiting for me.nice product,put it in then adjust it to size. let you know how it all works.
moparmatt
10-29-2007 02:12 AM
SIXSLUG
07-20-2007 02:54 PM
rjm022
06-30-2007 02:54 PM
Fishbait
12-05-2005 09:17 AM
Quick Reply: thuren trac bar?
