throttle position sensor
Old Nov 1, 2003 | 08:45 PM
cavemanscummins's Avatar
I am planning on installing a throttle position sensor tomorrow. What do I have to do to install it? anything special? disconnect battery, reset computer, hold gas pedal to the floor, etc...... Please let me know if you have done this before and what exactly I have to do. The reason for replacing it is because of transmission shifting/convertor problems.
Thanks James
Old Nov 1, 2003 | 09:19 PM
Srigs's Avatar
Re:throttle position sensor
Three suggestions.
1. Go to the 2nd Generation forum because they have a topic on this.
2. Search for TPS changing info.
3. Check out this helpful website http://dodgeram.org/support_pgs/tech_index.htm
Hope this helps. Srigs
Old Dec 21, 2003 | 11:42 AM
olivmatt's Avatar
you shouldn't have to spend $165 to replace it. buy a rewire kit. a new tps will not solve the problem in the long run...
scott hendren
gpcinc@yahoo.com
Old Dec 21, 2003 | 01:34 PM
infidel's Avatar
As Scott said a new tps may not solve your problem. But if you do it it will need to be adjusted which requires a voltmeter that measures less than 1 volt.
Good instructions on adjustment here.
http://dodgeram.org/tech/transmissio...TPS_adjust.htm
Old Dec 21, 2003 | 02:50 PM
kandgo's Avatar
Try everything else before replacing,the rewire kit does work if it is a wire loom problem,and some have had good luck with dissasemble and clean and reseal. Goodluck Rick
Old Dec 22, 2003 | 08:15 PM
olivmatt's Avatar
you really need to monitor the voltages at the pcm side of the harness while driving down the road. you will see the voltage spikes at about 1.8v... just tap the signal and run a voltmeter from signal to ground. easy. you probably don't need a new tps.
questions? let me know.
gabbyfan
Apr 30, 2004 08:10 AM
buckshot
Dec 29, 2003 02:24 PM
KATOOM
Dec 12, 2003 01:20 PM
twhite
Oct 31, 2003 10:50 AM
tishmael
13
Dec 2, 2002 12:39 PM
