For those with Moog ball joints - how do you get the boot on?
Old 10-11-2009, 02:42 PM
DTR question asker
dieselfuelonly's Avatar
I can't get the boot on my lower ball joints on my 2WD truck. The uppers ball joint boots just kind of slid on, but the lower ones look like they have some kind of metal ring in them that holds the boot in place. Every time I get one side of the boot on, I can't get the other side to give me enough slack to install it since the ring is so stiff. I've tried turning the boot as I press up, using some pliers, etc., but no luck.
Any ideas? Its really holding me up right now because I'm ready to put the steering knuckles back on.
Old 10-11-2009, 05:50 PM
dguru's Avatar
You could use a large socket or pipe about the same size as the OD of the rubber and tap it on with a hammer or you could just assemble everything and the nut will press it into place when you tighten it. I did the later.
Old 10-11-2009, 06:20 PM
mulisha's Avatar
did you see the threads about moog ball joints on here..the thread title was something like...new shocks new ball joints odd feeling..you might wanna read that.
Old 10-11-2009, 07:18 PM
bluhaven's Avatar
I just did mine today and I used one of the cylinders that was in the ball joint press tool kit. I know, I had a hard time, at first it would go all around except for one little spot then I used the cylinder on the boot and that worked.
Kevin
Old 10-11-2009, 07:48 PM
bluhaven's Avatar
I just read that thread and it looks like they are on the newer 4wd truck, different part # anyways? Just put mine on today so I hope there ok.
Kevin
JoshBrown
08-22-2010 03:24 PM
firebill1720
20
03-05-2010 09:23 AM
jtnm
07-12-2006 10:43 PM
360ramcharger
07-01-2006 04:11 PM
bigdogtruck
06-10-2004 12:29 PM
Quick Reply: For those with Moog ball joints - how do you get the boot on?
