For those that have used the Donaldson ELF lube filters on their CTD
Old 10-09-2005, 05:58 PM
billmac's Avatar
I installed my first Donaldson ELF lube filter today along with an oil change for my truck. According to the installation instructions on the filter, you have to tighten it 1 full turn. Unfortunately, I was only able to tighten it 3/4 qtr turn by hand and I had to use a rubber strap wrench to tighten the filter the last 1/4 qtr. I lubed the rubber filter seal with oil so that's not an issue unless I didn't put enough oil on it. Also, I always wipe the filter mounting surface clean after removing the old filter. Previously I have used Fleetguard Stratapore and Amsoil Superduty lube filters on my truck. On both of these filters, I was always able to turn the filters by hand to whatever they needed to be turned per the instructions. I was just wondering if anyone else experienced the same thing when installing the ELF filter. Thanks.
Old 10-10-2005, 12:28 PM
HOHN's Avatar
Hand tight is plenty tight, since you oiled the o-ring and threads.
cincydiesel
12-01-2010 12:46 AM
dssimecek
03-10-2008 04:58 PM
Geico266
12-05-2006 10:05 PM
billmac
09-17-2006 05:52 PM
Strjock81
12-20-2004 07:49 PM
Quick Reply: For those that have used the Donaldson ELF lube filters on their CTD
