These are no isspro but take a look
Does anyone see a problem with me using these cost effective gauges to monitor the old 12 valve? Will that vacuum gauge work ok for boost? I know I will need a needle valve and snubber for the fuel pressure. Id like to use the oil temp gauge for trans oil temp.
http://www.summitracing.com/parts/SUM-800160/
http://www.summitracing.com/parts/SUM-G2936/
http://www.summitracing.com/parts/SUM-G2938/
Thanks for your time gentleman.
Doesn't match the style, but this one would work.
http://www.summitracing.com/parts/SUM-G2884/
got it, thanks Pat.
Check out this package.
http://www.summitracing.com/checkout/cart.aspx
Using that oil pressure for electrical fuel pressure gauge.
bnold
05-14-2006 07:47 AM
