thermostat question?
Old 11-18-2010, 05:56 PM
cseby's Avatar
put a new cummins thermostat (#3802968) in my 1990 d 350.it will start to put out heat about 3 miles down the road.put the same cummins thermostat(#3802968) in my 1989 d250.it will not start to put out heat for about 12 miles.both are installed correctly.both heads have been cleaned up with a die grinder as per dodge service bulletin.what's the problem with my 89? this has bothered me for the last two weeks.i can't come up with an answer.
Old 11-18-2010, 09:43 PM
1992gen1_fan's Avatar
You'd just have to test the thermastats side by side and see which opens first, but all i can think of is maybe the one in the 89 might be a dud or somthin. i know my 92 used to take a long time to heat up and changing thermastat fixed that.
Old 11-19-2010, 07:55 PM
I'd try a different thermostat. They seem to be quite inconsistent.
Bookshelf
05-30-2009 01:17 AM
laker
02-04-2006 02:49 PM
Truck96
12-22-2004 05:55 PM
Truck96
11-14-2004 09:47 PM
blackboat
01-22-2004 09:53 PM
Quick Reply: thermostat question?
