Thermostat leak.
Old 11-16-2010, 03:03 PM
lmullen's Avatar
Thermostat leak.
93 cummins 12v
It seems to be the lift plate is not flat and leaks.
Can I just pull the lift plate and have that work o.k.?
Don't want to use gasket in a tube.
Local shop wants $200 to fix and flush.
Also, what do you think is best flush compound?
Accidentally posted in 24v
Old 11-16-2010, 03:24 PM
Copenhagenjunkie's Avatar
Thanks for the year and posting in the right section that helps us help you.
So my cousin has a 94 12v and I remember him saying there is a freeze plug or a threaded plug behind the lift plate that rusted out causing a leak.
Is that right 12v'ers?
Old 11-16-2010, 08:07 PM
GAmes's Avatar
Do you have a Cummins thermostat along with the Cummins gaskets?
BTW, you have a 1st gen pickup. You are still on the wrong forum.
SeanB23
05-30-2009 08:17 AM
Bookshelf
05-30-2009 01:17 AM
Diesel_Dan
03-02-2009 01:45 PM
TxDiesel007
02-18-2007 01:29 PM
mechanic
03-25-2003 08:45 AM
Quick Reply: Thermostat leak.
