What temps do you see pulling?
Old 05-19-2008, 07:55 PM
sallyman1's Avatar
On my edge juice engine temp read between 204 and 210 fahrenheit pulling my 9,000 lb travel trailer. is this normal? on my stock factory gauges the needle was in the middle. I also get a P0483 fan clutch code. Should my temp be lower if fan problem was fixed?
Old 05-19-2008, 07:56 PM
Spooler's Avatar
Noop, that is where it should be.
Old 05-19-2008, 08:08 PM
sallyman1's Avatar
Wow. towed my truck home. used father in laws ford f350 6.0 litre diesel 1 ton. Wow. It pulled my camper better than my truck pulls it. And hes got no chip. i tow lo edge using level 2. I smell ford coming my way
Old 05-19-2008, 08:22 PM
Spooler's Avatar
You say that now but when it goes boom going down the road you will be kicking yourself
Old 05-19-2008, 08:54 PM
sallyman1's Avatar
boom from what? atleast it starts. i had to tow my truck 200 miles home. wasnt cheap.
Old 05-19-2008, 09:42 PM
rich's Avatar
yea check your towing mileage on it and then put all the stuff you have on your ctd as far as chips and see how long that 6.0 really last
Old 05-19-2008, 09:45 PM
sallyman1's Avatar
i know im just mad. cummins is best. But that truck sure sails down the highway. mine seems to struggle. I used his on tow/haul (ford) and for a while put it on overdrive it had no problem. with my 2004.5 ram i always use tow/haul. If i try overdrive it wont pull it at 65 mph. Go figure. I know my dodge has 100 hp extra than hios truck and probably 300 ft lbs torque more (with edge level 2).
Old 05-19-2008, 10:11 PM
Spooler's Avatar
You have 3.73 gears I beat ya.......... 4.10 with the auto is the only way to go. Mod the tranny if you really want to put it down. TC, VB, and flexplate
And by the way I always use overdrive unless on a real real steep incline.
Old 05-20-2008, 08:05 AM
HOV
HOV's Avatar
Sounds like there's either something wrong with your truck, or you dad has an F750.
Old 05-20-2008, 12:10 PM
DBLR's Avatar
sallyman1,
I’m surprised to hear this from a Journeyman heavy equipment diesel mechanic!
Old 05-20-2008, 12:33 PM
bluepp's Avatar
Your truck isnt running right. You should be able to pull in overdrive with ease
Old 05-20-2008, 04:42 PM
sallyman1's Avatar
what you mean surprised? I dont have a scan tool. theres nothing i can do to my truck other than buy parts and start swapping them. or what do u mean? as far as the ford thing no i was kidding. cummins is best. but i think the ford has a better tranny than the 48re auto?
Old 05-20-2008, 06:43 PM
no_6_oh_no's Avatar
What everybody is saying is your truck has a problem and its not right. You should have no problerm pulling that weight even stock. Add minimal power with a tuner and you will be amazed.
Old 05-20-2008, 09:11 PM
sallyman1's Avatar
i did. i added edge juice.
Old 05-20-2008, 10:19 PM
snoyes's Avatar
Could be the difference between a 5 speed auto (5R110) in the Ford and the 4 speed auto in the Dodge. Also being a Dually he probably has the 4.10s vs the 3.73s. And overall the torque shift trans on the Ford has been OK, however, the 6.0 on the other hand...
Quick Reply: What temps do you see pulling?
