Temp Gauge
Old 01-06-2007, 10:16 AM
Haulsmytoys's Avatar
Temp Gauge
Hey, my temp gauge was pegged last night so freakin out I pulled over and checked things out. I recently changed the alt. and thought I screwed up with the belt but all was fine. As I drove home the temp. gauge was pegged again but when the motor was under load (accelerating and sometimes decelerating) it would momentarily drop back to normal just under 190. Did I screw something up when I changed the alt. or is some sending unit going bad.
Old 01-06-2007, 12:22 PM
Racer9's Avatar
Sounds like the sender, what year is your truck?
Old 01-08-2007, 09:23 PM
its a 97 with 185K on it
Old 01-08-2007, 10:25 PM
jrs_dodge_diesel's Avatar
Yep. If the temps were high enough to peg the guage, it should have boiled and sent coolant out the over flow bottle. Also if an engine truly has that high of a temperature, you should hear funny noises too.
Check the connection and wiring from the temp sensor located on the thermostat housing (points straight up if I remember right). You may have bumped it, or crushed the wired. I believe if the wires are shorted or the signal wire (there is a signal wire and a ground wire for this sensor) is shorted then the guage will peg. This seems like the case since the guage acted normal sometimes, this indicates to me a loose wire.
Hope this helps you.
J.R.
USCG Electronics tech 2nd class
mar67655
03-21-2009 05:35 AM
DennisT
05-11-2007 08:58 PM
turbox2
02-06-2006 07:44 PM
Bad Ramer Jamer
12-01-2005 02:30 PM
firesine
11-24-2005 10:58 AM
Quick Reply: Temp Gauge
