Tech Tip (Front & Rear Diff Service)
Old 05-29-2010, 03:58 PM
06RAM2500's Avatar
When you go to pull the covers off the differentials, you'll notice some dirt stuck to the pumpkin, on the outside of where the gasket seated. Well one way of cleaning the surface is soak a rag in some of the oil that's in the drain pan. All the dirt will stick to the rag, and not end up in the gears. Also saves you from using a ton of brake parts cleaner.
Txwelder
02-22-2008 04:55 PM
jwhip
05-22-2006 12:21 AM
Smkndzl
06-27-2005 11:01 PM
lucey
06-20-2005 09:02 AM
jrs_dodge_diesel
23
11-25-2004 12:00 PM
Quick Reply: Tech Tip (Front & Rear Diff Service)
