in the tech articles
Old Mar 28, 2006 | 10:19 PM
flashgordon's Avatar
In the "tech articles"
Is the fan clutch and fan for a 89-93???...part#52026653/52028760
Old Mar 29, 2006 | 11:11 AM
Probly will need an admin. to ansor it......any body?
The topic was by Monty..... any help would be grately arprisheated.
Old Mar 29, 2006 | 09:28 PM
Monty's Avatar
It should be for 89-93. You can confirm this through your dealer to make sure.
Old Mar 29, 2006 | 09:55 PM
Thanks for the responce
I have a cooling problem in the summer so i thought that this would be a good idea!
I checked with my dealer and he said that it was still avalible but that it fit 94 and on.
he check my fan and clutch part# but thay didn't up date to these part#...But will it fit? are the fan shrouds the same or similer, that i could yous the steeper piched fan and fan clutch?
I replaced my fan clutch a bout a year ago and it helped a lot(the old one made no noise when it got hot!) but it still trys to over heat when i'm pull a hill with my car and trailer!
Any help and info that you can give would be grately apreseated!
flash
Old Mar 30, 2006 | 05:23 PM
Monty's Avatar
Those numbers are right and they will at least fit a 90 model truck.
HERE is a thread discussing it.
Old Mar 30, 2006 | 05:45 PM
Thank Monty, vary much,aprisheat the link
when it get hot this summer i'm going to try it and let you guys now how it works!!
I'm some one that has to check and check again before i make a move!!!
Monty thanks again for you pashents.
Old Mar 30, 2006 | 07:56 PM
Monty's Avatar
Your quite welcome.
Shovelhead
Oct 19, 2009 08:00 AM
Smkndzl
Jun 27, 2005 11:01 PM
