TC unlock in D at WOT
Old 03-15-2007, 09:39 AM
royta's Avatar
TC unlock in D (OD locked out) at WOT
When I'm in 3rd (D), and OD is locked out, I can slowly accelerate and the torque converter will be locked up. I can keep on acclerating slowly, and then when my throttle linkage hits a certain spot, the torque converter unlocks. Yes, I know it's the combination of the TPS voltage, at the higher end of the throttle, and the PCM knowing I'm in 3rd with OD locked out, but what is the point behind it? Is the only thing I can do, other than backing off the TPS, is to install a lockup switch?
cLAYH
02-07-2004 01:28 AM
mcevins
07-16-2003 07:01 AM
dsljunkie
04-11-2003 11:47 AM
hellotbone
16
03-31-2003 08:28 PM
LHartman
12-25-2002 11:07 AM
Quick Reply: TC unlock in D at WOT
