TC keep unlocking and locking
Old 10-10-2005, 10:55 PM
dozer's Avatar
Hey guys. My TC feels like it is unlocking for a sec. and locking back up, the rpms jump also. It happen while in OD or D hot or cold at 50mps or so only at light pedal or cruise speed. I do have a lock up switch and it will not do it if switched to lock up. In the morn ill check fluid levels and wire conections on the lock up switch. I also changed the tranny filter 3-4 months ago. Any help thanks.
Old 10-10-2005, 10:59 PM
dozer's Avatar
Sorry. Its a 98.5 2500CTD 4x4 with a 47RE
Old 10-11-2005, 06:46 AM
j-fox's Avatar
First --- slow down. 50 mps is real fast!!!!!
Just kidding, I know it is a typo.
Most likely this problem is electrical noise. It is from the alternator. DTT has a filter that cleans it up and other noises as well.
First you can try cleaning all grounds.
Do a search on it.
Old 10-11-2005, 08:20 PM
dozer's Avatar
Did some searching last night and dug up some good treads. Drove around holding my brake pedal up with my foot, the TC still unlocked so i can rule out brake switch. I did find a loose ground at the bat. put a wrench to and it appeares to have gone away. If it acts up again ill look into the TSP sensor and running seprate wires to the ECM. LAst thing will be replacing the TPS.
Old 10-11-2005, 08:26 PM
Tazman's Avatar
Cleaning up the battery terminals usually looks after this
Old 10-12-2005, 10:52 AM
Wolfeman's Avatar
Cleaning the battery terminals is probably a temporary fix. Call DTT and get a noise filter, about $40, this usually takes care of it.
weldman05
10-26-2007 09:24 PM
bcool
07-14-2007 11:32 AM
dltriolo
28
03-12-2007 06:45 AM
whosyrdady
09-25-2005 11:07 AM
Quick Reply: TC keep unlocking and locking
