Tapping Into Interior Lights
Old 05-11-2007, 08:11 PM
pet05's Avatar
I am looking to install a LED that will activate when the interior lights are turned on for night-time driving. I am looking for a source around the bottom of the dash, near the steering wheel.
The LED has the built-in circuit protection. Has anyone has problems with wiring an LED to the interior lights??
THANKS...
Old 05-11-2007, 08:58 PM
Festus's Avatar
THANKS...
Yes, I had a problem. I tried to wire an LED to the positive wire going to the map lights behind the overhead console. The problem was when the ignition is turned off, the puter limits/cuts 12 volt power to that particular circuit.
I had to get constant 12 volt power in the engine compartment from the hood light no less.
Old 05-11-2007, 10:57 PM
Turbobob's Avatar
When you say "interior lights", I assume you mean the dash lamps? If so, I installed a 5 LED light bar above the center console to illuminate the cupholder area at night. I just tied it to the dimmer wiring for the heater control lighting. The LEDs dim with the dimmer ****. Works great!
Old 05-11-2007, 11:06 PM
Turbobob's Avatar
Sorry....Just re-read the post. You mean the dome lights/map lights. It shouldn't be that tough. The wiring for those lights run up the A pillar. Should be able to tap in there.
Old 05-11-2007, 11:07 PM
Luvnacumns's Avatar
Turbo bob.... PICS??? I'd like to see that in action...
Shane
Old 05-11-2007, 11:14 PM
53 willys's Avatar
Shane
X2 on that buddy
Old 05-11-2007, 11:15 PM
Turbobob's Avatar
Just looked in the service manual. The wire has a color code of "YL/LB" which I believe is Yellow/Light Blue tracer. This is the wire that comes out of the module and powers the dome lights, vanity lights, and the map lights. Hope this helps!
Old 05-11-2007, 11:17 PM
Turbobob's Avatar
X2 on that buddy
I'm a bit of a computard...so I'll see about getting you some pics. I bought the LED lamp bar from superbrightleds.com. Was 11 bucks, plus shipping. I bought the green one, kinda matches the dash/radio lamps.
Old 05-12-2007, 12:38 AM
pet05's Avatar
I was looking to install an LED to light my toggle switch for my Pac Brake. Being that LEDs draw very little power, I was figuring maybe just running a direct line (fused, of course) from the battery. They would always be on, but they would NEVER drain the battery.
How does that sound??
ehammett
13
12-30-2008 05:20 PM
chvyhs
07-02-2008 02:27 AM
MustangHauler
04-01-2006 01:49 PM
MSimmons
02-02-2003 02:09 PM
MARKY MARK
01-25-2003 10:30 AM
Quick Reply: Tapping Into Interior Lights
