tapping banjo for pressure guage
Hi everyone, I am getting rady to tap the banjo fitting with 1/8 npt but I don't know what size drill bit to use (the tap does not specify). Also what should I use on the threads to seal them? I have heard to use permatex #2 and loctite 545. What do you guys think?
The pipe taps , and pipe threads in general are tapered , so using any drill bit that is big enough to get the 1st few cuts started into the hole is what you need .
As apposed to using a larger bit , and then the threaded hole will be lose .
When you get the tap going , pull out every so often , and check the fitting you want to put in , you should go about half way up the threads of the fitting [ hand tight ] with enough left to tighten with tool .
I use teflon tape , but make sure that the tap is not near the beginning of the threads , so to let any teflon into the pump , also about 3+ layers of tape .
For 1/8" NPT, a letter R bit is what you want. Failing that, 11/32" will work just as well.
I use permatex thread sealant, in the white tube. Not sure the number on it. I would avoid tape, last thing you want is an errant strand getting into your fuel pump. Use the sealant, keep it 2 threads back from the end of the fitting.
vulcan performance can hook you up with some fittings and hose to run to a pressure sender. Infidel's setup tips were also very good.
Youll need a snubber valve of some sort. Whether it is a restriction in a fitting or an adjustable valve.
Drill 21/64" for 1/8" NPT tap. But, do not drill all the way through the whole bolt, once you go through the bolt head - the drill bit will open up the threaded portion, you don't want to weaken the threaded portion. Once you're through, stop and tap.
P.S. You will have to use 1/8" NPT bottoming tap or make one out of regular tap by grinding off 1/3 of it. Full length tap will not work, it will not cut deep enough before it sticks in the threaded part of the bolt.
erf2006
04-12-2008 11:18 AM
8mpg
15
06-08-2007 05:51 PM
ptgarcia
08-18-2006 03:52 PM
bigragu
01-24-2006 11:16 AM
CTDHokie
07-22-2004 05:24 PM
