where to tap in for fuel pressure???
Old 03-19-2004, 11:06 PM
silverram323's Avatar
I bought the Westach - Fuel Pressure Gauge Kit - 0-16 psi from Genos garage. Is the only place to hook up to is the schrader valve or get the banjo bolts with the 1 of them being tapped?
I have it hooked up to the schrader valve now and it vibrates loose and leaks fuel all over. What else can a guy do???
thanks
Old 03-20-2004, 12:44 AM
billg's Avatar
See if this will help.
http://www.villageforge.com/fuelgauge.pdf
Old 03-20-2004, 08:04 PM
dakar's Avatar
I just installed mine last weekend....Used a tapped banjo bolt at the bottom of the filter housing... works like a champ...no leaks, no fuss...you'll need to get TWO new gaskets...
Dave
Old 03-20-2004, 08:08 PM
Well i ordered the banjo bolts, Ill try these. If I remember right arn't these bolts also bigger in size then the stockers?
Old 03-20-2004, 08:15 PM
Administrator / Scooter Bum
Shovelhead's Avatar
The thread size is the same, the holes that the fuel has to pass through are larger.
Old 03-20-2004, 11:59 PM
billg's Avatar
Just be careful don’t over torque them. I’ve heard of a couple of guys twisting off the heads of the bolts. The book calls for 18ftlb. I would just get them good and snug.
Just my $0.02 worth.
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
alto22
34
02-16-2007 09:28 PM
Hoss
04-11-2006 11:37 PM
bgilbert
03-02-2006 04:01 PM
Quick Reply: where to tap in for fuel pressure???
